Q1:also. q.whats is the ration of standing ladders?
1/4
1/5
q. A transformer has a primary winding with 1100 turns and 380 secondary turns. It is connected to a 230v supply. What will the secondary voltage be?
how do you work this out?
and questions on power factor would help
my redi remember theses question so will u answer them for me aswell thanks.
Q.an electrical relay which causes contacts to open or close is.?
Dont understand this?
Q.an overcurrent protective decice is one which relies for its operation on?
And again...
Q. purpose of a circuit breaker in a circuit is to provise protection against?
This is very basic... overload and short circuit....
Q.earth fault current will flow in a 3 phase installaition if?
there is a low enough resistance?
Q.which type of protective device can discrimate between short duration overlaods and high current ppath?
A. rcd -this does not have any overload protection
B.type b mcb this will trip fairly quick on overload
c. rewirable fuse[takes longer to melt than a type B would trip
d. can not remembermaybe not this answer then
it is pure resistance.another questonpower factor is at unity when?
if you can try and remeber the first 2 questions.... minds gone blank to what i correct questions could bethis test is baffling me
"Ratio" for putting ladders up 1:4 1/4also. q.whats is the ration of standing ladders?
1/4
1/5
a-RCD the red herring optionright chaps i have now failed the exam 3 times and my time is running out.im failing on the electrical principles,theory and operatiuon part. any help please
could they be getting at a contactor???
i.e. relay normally DC operated
low resitance fault path, e.g. Earth loop impedance readinmgs???
Overload currents melting the circuit cables?
either one of the phases is in contact with earth??
A. rcd
B.type b mcb
c. rewirable fuse
d. can not remember
sure? i would imagine the 'short duration overload' in the question is something like a motor. in which case, a fuse would hold up better than a type B, which could trip before motor has got to speedQ.which type of protective device can discrimate between short duration overlaods and high current ppath?A. rcd
B.type b mcb
c. rewirable fuse
d. can not remember
the answer is B, a MCB can discriminate between short duration overload (inrush of current), and overload if correctly rated.
it could be that answer D is BS88.... in the original post he couldnt remeber Dthere is no correct answer here. I feel this maybe a question that has not been copied on to this forum correctly???? or is that just me
