That doesn't make him un-competent. Where does it say he's 2391 anyway?Listen if you aint got the 2391-10 you haven't proved your competency in Inspection' date=' Testing and Certification and if you aint got it your not fully qualified.
Peolpe without it mock it because they don't have it. Its the hardest exam for a reason lads 60% fail rate. Because its the theory behind the saftey of all installations![/quote']
Firstly he is using NIC cert labled Domestic PIR........which is used by members who have been assessed by NIC he needs 2391 for that...
having a piece of paper doesn not make you competent....
using your logic a 5DW with 17th and 2391 passed while on the course makes him competent ???????? er nope
you do not need 2391 to do a PIR
GN3 1.2 does not state you need 2391
"The inspector carrying out the inspection and testing of any electrical installation must,as appropriate to his or her function,have a sound knowledge and experience relevant to the nature of the installation being inspected and tested,and to the technical standards.The inspector must also be fully versed in the inspection and testing procedures andemploy suitable testing equipment during the inspection and testing process"
no mention of 2391
Furthermore.....
if i do domestic work day in day out then i can class myself as having sound knowledge and experience
therefore i consider myself to be competent without 2391 !!!!!!!!!
---------- Post Auto-Merged at 19:22 ---------- Previous post was made at 19:20 ----------
Competency is holding the correct qualification in that field as you need to show competence in passing the exams and experience on the tools of which you pick up over time. Since I went self employed I've found it a huge learning experience and I've found this forum extremely helpful in that. I feel that there are too many changes occurring in this industry with the regs as you just get used to them and then some changes are thrown in to keep you on your toes and I find some of it confusing TBH. Hence some of my questions in the past. I'm sure I'm not the only one on here that feels like this.
what publication says that ??????
