25a mcb
Ucatchmydrift
Jun 21, 2022
135
31
Suffolk
Hi chaps, im building a diy pv system. The inverter instructions reccomend a 2 pole 25amp breaker inbetween the inverter and the load.
Im considering this one:
https://www.electricalcounter.co.uk...ksb4KC55n_Y2K4e2Dx8-NpzmFeenAXMhoC4RwQAvD_BwE
But in the above advert, it says:
  • For use in Cudis CPN consumer units, 3 Phase distribution boards, and mini enclosures only
Does anyone know if this would be suitable for single phase?
Thank you 👍👍
(also, if so, is cudis a reasonable make? Thanks..)
Irrespective of whether it fits or not you are not meant to mix and match circuit protective devices
Ok,, do you mean the makes of them? So for eg, i will have a mcb and isolator in the shed (pannels are on two shed roofs) (after inverter), swa cable into house, then an mccb 30ma type b in the house and isolator contained in a metal consumer unit. - everything needs to be the same make? Even the consumer unit? - thanks..
Ok ive had a little read, and if i were to go for the cudis mcb above, i wil just use a cudis consumer unit.
But, still wondering if the above mcb is suitable for single phase and if cudis is actually a reputable make?
Thanks..
Thanks..
the make is cheap and nasty, but should do the job. It can be fitted in any din rail enclosure like this -
https://www.tlc-direct.co.uk/Products/BHCT2.html
