Hi, I am a non electrician who desperatly seeks some advice, your help would be truly appreciated.
I am installing some equipment outside, near water which is approximatly 100m from a plant room. The outside area between the plant room and the equipment is is accessable by the public. The equipment operates: 480v 3 phase, 25amp, 60HZ, 7.5KW WITH 2880/133 REVOLUTIONS PER MINUTE. tHE PLANT ROOM CONTAINS 3 PHASE.
I unsderstand that traditionally permantly installing 3 phase supply is very expensive, can I hook up an extension cable obviously this is no normal extension cable and I would like to understand the equipment required and cost involved - I will NOT be doing this myself but I am trying to identify if this is possible and a likely cost - this could make or break the project.
I am extreamily grateful for your help
Kind Regards
Scott
Kind Regards
Scott
