these are some photos including the repairs i made, the crimped cable finished in a plastic choc box but i didnt get a picture, the owner had a handy man headbang install a light outside with a pir unit controller and low voltage pir that also got connected to the existing porch light fitment. the porch was run in single from the hallway double switch, and the handy man double backed the live supply from another trip including a neutral to the porch light aswell. when the house lights tripped and the porch light switch was turned to on position, this would allow the pir controlled part still being turned on on its own trip to back feed the circuit to the house via that porch fitting connected to the double switch in hallway if triggered outside. which is linked through as a live feeding the rest of the house, this was potentially life threatening and he wanted it removing and doing properly, this meant him buying a pir lantern and taking a feed direct from c/u to the light via sw spur,.
