No I am NOT saying ANYTHING different to what I have said before.
You have 3 unknown resistances.
You have one in parallel with two.
How do you know what the current division is between the three resistances to get the voltage?
Look at the diagrams I have drawn, I can't see yours at this end as they have not come through well., not your fault, but a limitation of the method I suspect.
In the delta configuration in your example you have an unknown current dividing between 3 resistors, of equal value, one in parallel with two in series, now if you don't know the current flowing, how can you derive the current division?
If you don't have the current division, how can you have the voltage division?
