The wires are copper cored.
The wires are 2.5mm sq.
How can you tell if the internal wiring configuration of the motor is star or delta?...
Ok I have been pondering this for a bit...
doing a few spreadsheet calcs ands sketches..
considering several options of strapping and/or connecting other components onto one or more terminals to see if any different values or ratios can be obtained between star & delta...
But as the motors are balanced and all we have electrically to start with is a resistance between any two terminals then whatever we do to a star motor will give the same readings as if it were also a delta motor...
i.e. electrically they are identical...
Say we have a continuity between any two terminals call that "X"
all we can then deduce is
i) If it is Star then each coil will be equal to (0.5*X)
ii) If it is Delta then each coil will be equal to (1.5*X)
iii) If any two terminals are shorted the continuity via the non shorted terminal will be equal to (0.75*X)
e.g. using easy numbers if x=20, Star,(0.5*20)=10, delta(1.5*20)=30, strapped(0.75*20)=15.
So you just end up going round in circles with electrical calcs...
BUT...
What about physical dimensions....?
We know our 'X' reading and we have two possible solutions for the coil sizes
0.5X and 1.5X
According to the snake these coils are wound from 2.5mm copper wire....
How about if you calculate the length of copper needed to achieve either of the two possible coil resistances..
Wind them up..
see how big they are and if they would physically fit inside your motor??
By my reckoning you will have two possible coils one of which is three times the size of the other....
Then if you have to fit three of the said coils inside you motor housing that you have in front of you..
It just may be physically impossible to fit the one option inside???
Or one may look like its going to rattle around cuz there is just tooo much motor space ...
opcorn
