Canoe tell me more, is it being pulled around by another force or do I have this wrong as well?
yes I do know that lifts have speed controls and brakes
Good grief !!Canoeboy said:And just to add something to the mix and confuse issues :slap
If you have a 300kW 50Hz motor - 6 Pole - 1000 rpm base speed - slip 100rpm so nameplate rpm = 900 rpm
What happens if you drive this at 1100rpm ?
yes, but the storeman has put it with the data plate from the motorIm going to do some more reading but for now do we have access to an oscilloscope?
The numbers in the solution were just for illustration. It will work for any motor because it's the percentage difference between the two tests that gives the answer. If the 2 tests give a 33.3% difference in their results the motor will be internally delta connected, if the difference between the two test results is 25% the motor will always be internally Y connected.........Your attempt is a valiant one, but, it used numbers, we have to avoid numbers because then we have to prove it works for every possible number,
