extracampine
- Oct 21, 2017
- 11
- -2
I replaced the standard double wall socket in my new build house with one of these:
http://www.furutech.com/2013/02/02/1858/
The old wall socket had some sort of plastic cover on the back, that presumably connected the terminals of the 2 sockets in the block. The new one has no such connections and has separate sockets.
The live/line and neutral wires were not an issue as there were 2 of each and I was able to wire 1 to each socket. There was however only 1 earth wire coming into the box. I wired this to one of the sockets, and connected the 2 earth terminals of the block with some further cable.
Please see the pictures below for how I did it. The connecting earth cable is not yet connected, though I did connect it after the photos.
What I would like to know is:
1. Did I do it right?
2. The cable connecting the 2 earth terminals is made up of a few thin strands of copper, whereas the earth coming in from the wall is made up of 2 thicker strands of copper. Is the cable with the thinner strands OK to connect the 2 earth terminals?
3. It is a plastic box that the faceplate screw into. Do I need to connect the earth of either side of the plug to the box in an way (i.e. to one of the screws)?
Thanks!
** MODERATORS COMMENT **
Assuming this supplied from a standard 32amp ring circuit, then this method of removing a double socket outlet and fitting two single sockets is a significant danger to the integrity and safety of the whole circuit. There will now be incorrect overload protection to the whole circuit leaving risk of damage to the cables, overheating, or electrical fire in the event of a fault.
It shows a direct breach of wiring regulation 612.2.2 as the ring continuity has clearly not been checked following the alteration.
It fails to follow the guidance of numerous other wiring regulation or the standard circuit arrangements illustrated in Appendix 15 of BS7671 wiring regulations.
This wiring method could be considered as dangerous as removing a good set of tyres off a car and fitting tyres with little or no tread. The car will work, but in an emergency it will probably not stop you quick enough.
Thanks!
