Old Time spark
- Dec 16, 2018
- 8
- 1
Installed a fire alarm system in a new premises using the AICO units, all manual call points were installed/wired into flush back boxes, as I have done since the days of AFA and Gents to KAC.
On final fix found there is no way to flush mount the Aico MCP401RC call point, and as it is next to an exit door and the walls are plastered and painted hit a problem.
Customer wants unit flush, as planned, but Aico say not possible, with quite confusing information,
Unit need to be surface mounted to access reset key and clip holding from in place using key. They would not say what the connections do, Earth, N, IC, L So I assume this is earth, Neutral, interconnect, and live. They state the IC is about 7 volts? so cannot use a relay or anything else if used another make of call point.
Have I missed something in new regs, do they have to be surface now? or has anyone got a suggestion for getting a flush call pointed fitted on an AICO system, seems like R&D at Aico need to look at this.
