Allen Keys
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Just wondered what Allen keys you all use. Had mine nicked from toolbag so need a new set but wondered what everyone else uses?
Cheers
I have 2 sets both ck 1 is a combined set and the other is a set that are separate ill try find links
I carry toooo many allen keys!
I have short & long arm metric & imperial from 1.5mm to 24mm & < 1/64" to 3/4", loose
T type straight here:
https://www.cromwell.co.uk/KEN6016470K
T type ball end here:
https://www.cromwell.co.uk/KEN6027800K
Screwdriver type ball end here:
https://www.cromwell.co.uk/KEN6022560K
I also carry clips of metric & imperial ball end like these here:
http://www.mscdirect.co.uk/EKL-13222H/SEARCH:CATEGORY/product.html
& metric & imperial straight here:
http://www.mscdirect.co.uk/EKL-10022C/SEARCH:KEYWORD/product.html
I also have penknife type sets in straight & ball ended, in both metric & imperial, some of these are SnapOn, however, they are similar to those in the links below:
https://www.cromwell.co.uk/KEN6028170K
https://www.cromwell.co.uk/KEN6028070K
I also carry torx keys & ball end torx keys, along with torx, metric, & imperial, hex keys, straight & ball ended with adaptors for 1/4", 3/8" & 1/2" drive socket sets & the socket sets to go with them
This:
https://www.cromwell.co.uk/KEN5827995K
this:
https://www.cromwell.co.uk/KEN5824896K
& this:
https://www.cromwell.co.uk/KEN5826185K
The other bit adaptor sets are not so easy to link to as I have bought them over the years, mostly Sykes Pickavant & Britool (old Britool, not the new stuff.
Mind I am just as likely to be found stripping the mechanics out of a CNC or conventional machine tool as I am undertaking electrical work!
HTH
I have one of those Dave, think its CK, but not sure,
Other Allen keys I have, some Draper, and set of Teng, have a set of Beta, but at >£60 may be bit steep for normal use! :eek:
Also have a set that fit on my ratchet, along with some Torx and anti tamper bits, both ratchet and normal.
Have a load of mixed keys as well, makes various and unknown.
Can you not use the screwdriver pictured above and put another driver through the hole then u have a t shaped Allen key insulated for only a tenner and if u use a long one u will get more leverage
m4tty,
If you are working on new kit it will be metric.
Imperial hex keys went out on UK/European/Far East new kit over 30 years ago
However, if you are working on older kit or US kit more than 10/15 years old you may find this kit still using inch sizes.
Ive got an insulated key for the Henly cutouts one of the guys from scottish power gave me it in a swap for a column door key, they have loads with them come with the cutouts.
As for allen Keys mine are made in the USA by Eklind i have two folding sets the blue metric and red imperial i find them excellent i also have there T bar keys in 4,5 and 6 mm for fitting lanterns.
Dave, your looking for a Henley key. My local independent sells them for about £6 . They have a full 360 degree shroud and insulated shaft for live working, but of course you dont practice that. I have had a google and cant find one online, but can get you one if your stuck.
Yes please. Next time you are there get one for me, cost the postage and send me a PM.
