This has been confusing me for a while so maybe someone can explain.
It's to do with computers and the power circuits supplying them.
Often on the forum it's stated - 'don't RCD a circuit supplying computers as they leak current to earth'
This bit I get - functional earths etc.
What I don't get is this:
The way I understand it is that the power lead enters the rear of your
computer and the first thing it comes into contact with is a step-down
transformer - right or wrong??
If this is right, then the primary windings will be completely seperate from the
secondary windings.
We all know that RCD's monitor the balance of current in the line and neutral
conductors - not the actual leakage to earth.
So surely any fuctional earth leakage on the secondary side of the
transformer (computer circuits) will not be registered by an RCD monitoring
the supply circuit on the primary side, even if they're using a common earth.
Or have I missed the boat completely??? ?:|
Cheers
secondary windings.
Cheers
