davetheglitz
Electrician
I'm sure this is obvious to a lot of you - but I've just got this straight in my mind and thought I ought to share it!
I have trouble explaining bonding to customers as to quantify the chance of your water pipes going live is a million to one.
However - with TNCS if the neutral connection goes open circuit before the incomer - then if any appliance is on - even a low wattage light - the earth connection then effectively becomes live. If bonding isn't in place then if you touch a kettle body and a tap for example you will get a nasty shock. If not on an RCD it could kill.
I've seen loads of main switches where the neutral connection has burnt out. For this to happen before the incomer to my mind could easily occur as human error or a limp wristed electrician. Far easier to quantify than someone shorting line to the water supply with a mechanical digger!
Perhaps this is the justification for 17th edition using RCDs everywhere - makes more sense to me.
Is this new to people or am I just a thicko!
