green-hornet
Distinguished Member
- Feb 25, 2009
- 3,741
- 0
This is very interesting but some people may have missed out on some very common faults with modern house building, that have a dramatic effect on earthing arrangements.
Years ago all services into the home was via metal pipes, even gas for you young plumbers out there.
Nowadays almost everything is in plastic.
Effective earthing with all TN systems had a backup with earth bonding to gas and water or any other services entering the property.
The problem with PME supplies are, that, not only does it carry a fault from your home, it does so for every home on the circuit, which are all sharing one cable back to the connection to earth at the distribution site. With connection through metal service pipes this would not be too much of a problem.
The way I like to look at it is like broadband the further away from the supply the slower your broadband speeds.
One word of warning though, you should never change one for another. Its up to the dno, you can always call them and discuss any faults you have found and they may reccomend a change to TT but THEY have to disconnect the link from neatral to earth, not you!
