Antique Volt/Amp meter
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Been given this which used to be my granddads who was a 'wireman' by trade.
Has anyone seen one of these before and/or know how it works. I believe it has a wire inside attached to a mini croc clip.
Anyone recon it could be worth anything. Im going to keep it and hand it down to my kids well whichever one carries on the trade lol.
Cheers
It's a DC meter.. Sharp pointy bit on +ve and -ve connects to stud on top,,,, by the look of it?
Looks like a DC ammeter.....but if it is an Ammeter it should go in series with the cable, so I am guessing that you disconnect the cable in question, connect it to the top stud and then touch the pointy bit on where you disconnected it from...if that makes any sense??? To connect the '+' to one end and the '-' to t'other would be the most likely way of winning a quick 30 minutes one way trip-out with Rev James or one of his 'mates'
I may well be wrong [see wife for details/history]... :coat
Some sort of Battery tester I'd say.
I like to see old electrical gear TBH . I used to have an ancient clip on ammeter , called AVO Tong-TEST I think, great big thing , up to 500 amps .
It was dumped in the great Clear-Out of 1990 .
Although I have modern Steinel type testers I still use the old Drummond set as second tester.
I've only seen one of those before in a picture,, never in the aviation industry, and I have worked on some reasonably old stuff,, Buccaneer was one of the oldest for me
Where's your Buccaneers............................................on the side of your Buccan head!
I've still got a wind up megger in a brown Bakelite case.
(and no I don't still use it, but it would in fact do it's job well if I did)
Perhaps your meter is basically a volt meter (go on, connect it to a 1.5V battery and see) and the Amps scale was for use with a shunt that you could buy for it?
