Anyone else had this dilema before ?
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Job on my own house , need to move supply /meter  from kitchen to enable forming a downstairs toilet .
DNO guy  called  to locate where to dig for supply cable  ( Doing it myself)   .  He was a bit nonplussed that I wanted to fit a unit in the meter cupboard to connect  10mtrs  SWA sub-main ....not come across it before.
I know that they don't want any other gear in there but their own but his boss had agreed as long as they can finish at their sealed DP isolator .   Hence I fitted one myself to make sure there will be room  when the jointers come .         There is   just enough room for cut-out & meter .
best remove that plastic, highly flammable, non AMD3 compliant REC2 so the DNO can fit their own
there probably used to seeing a bit of SWA bunged straight into meter / REC2 with the earth chopped off
Well Deke me ole china, you could have saved yourself the aggravation. Apparently the dnos and Niccy/IET have agreed that a switchfuse is not required in the instance of using swa as meter feed as long as you terminate the swa correctly.
http://www.charlesendirect.com/products/earthings-accessories.aspx
i have been fitting these on a new build site last year. Everyone is happy with it. :C
Thats what they normally fit ......is'nt it ?     They don't bother about metal enclosures   ie:     Cut-outs  & meters  ..all likely to burst into flames  at any minute  .
I only held that in place to see if there was room  then thought I may as well fit it as its a bit tight under flameproof , Amd3 ,  bulletproof unit  and have their REC2 off them  .
You jumped in there Sharpie .     That  device is  interesting!!     To my way of thinking , my switch would do but the guy said they have to finish  with  a switch  sealed  on their side .     Which DNO do you deal with ?
I'm guessing the CG box is a switch fuse - so why did you bother with the isolator?
That's VERY interesting - where is this stated as facts?
Give them a call, they will confirm. I believe   I called IET tech line to confirm.
I think it was either western power or yedl.
So that's not a blanket approval and unless its in black and white we may as well forget it. The EDF chaps around me, who are ex SEEBoard, are right little hittlers......
i cant see how that would be compliant. you would have single insulated conductors from the SWA
I was told it is agreed with all dno’s.
That was the very reason I checked this out.
Yeah this is Western Power , I think they'll be OK with it .
As I said  ,  they HAVE to finish at a sealed isolator ...mine  has no sealing facility  , I just needed somewhere to make off the SWA .
Mind you, given what Sharpend is suggesting we would still need to fit an isolator, then a metal enclosure to make off the SWA!
I still don't see why they need to seal the isolator - as the DNO fuse should have a seal on it, what would sealing the isolator achieve?
I had that on the last new build  ..... long run of meter tails in a bungalow , fitted a KMF  80  with tails awaiting the meter monkey .   He fitted them  but was sent back to squeeze in a DP switch  with seals.      He also left me with this piece of expert nonsense .
@Murdoch I quite agree, but then I dont make the rules.
That must have been his first insulation resistance test!
