The panels are the same shape, but thinner. The electronics are the same units but VAG turn things off the further down the range you get, like VW don;t do a total closure option but you do on Audis so mine just has everything turned on, saves buying an Audi!er, lurch, no the panels are no different and mine has all the same electronics as the relevent golf thanks
Nothing yet, mechanically it's all just the standard 6 speed sport. 170BHP and 300 lbft is where I'll wind it up to. Beyond that I need to look at whether I want to keep it and start changing the DMF etc... and stick some more go in it or just buy something else, depends what's about at the time. The VW should keep going for another few years yet though.what have you changed on the 1.9 or are you going to be happy with 160bhp?
That does sound like it's got some poke. In the passat the 1.8T will give about 235 after a remap and it just keeps going, I've never driven a car that just pulls all the way through the revs. I would have to stop using the car for work if I kept buying petrol turbo motors!my octavia(which should be working some, finally) is a 1.8T with large fmic, equal length tubular manifold, gt2860r + external wastegate, full 3" intake, 3" downpipe, decat, 2.75" exhaust, large port high flow inlet manifold and a few other things that i have probably forgotton and should be making around 330bhp when mapped. thats not the fun bit though, i already have a gt3071 sat ready for when my spare engine is rebuilt(currently being built with a standard long block) that should be far more interesting!
Yep. Think it's being replaced with a 3.0 V6 CDTi next though.i take it you mate thought he had a 150cdti then?
Probley all ringers and the guy couldn`t get rid of em lol ROTFWL10's and 10's and 10's of thousands of pounds worth sat there if they are all complete and working(or at least were), must be a reason for it.
I don;t care, not my car.sorry lurch but without wanting to turn this into an arguement i have spent enough years on various car forums to know that 1.8T's with a K03 or K03s don't map to 235 on reliable rollers, not without destroying turbos anyway,
Ah yes, the turbo, forgot about that. I wasn't in this for the factual correctness, no arguments started, I give in as I CBA to look at the info again ATM.the same goes for 170 from a PD130, mid 160's is about tops without blowing the turbo up.
That would explain why people have been saying not drive it too economically. Not sure what to do with the car yet, once it's working I can either sell it or start swapping things and remapping it. All depends on what else is about when it's working, I don;t mind sticking the VNT17 on it and dropping the DMF out and whacking it in the skip, I may have lost interest in it by then if there's a newer, shinier thing sat waiting to be fixed. There's an RS4 that wants a new front end on that looks nice, from the back obviously.lol, fair enough. you can destroy the dual mass flywheel on standard power, hell even the 90's and 105's can as its down to how you drive it more than what power you've got, if you use high gears at low speed(so low revs and high load) you'll break the flywheel quicker than high power and higher revs.
That I could beat quite easily.come on children,you are fighting over pushcarts,
mine kicks out over 280BHP/litre
0-60 in under 3seconds
That is why I haven;t, I'd never make any money. I'd have to chargeand somewhere in the region of 15mpg.
That I could beat quite easily.what part? what with?
All of it, with something with more of everything. Not saying I've got anything that will at the moment, but it's not an unbeatable set of figures.what part? what with?
