Still working on various paperwork, but keep looking back at the report. Really busy at the moment and cant spare any time in the day
There is always a balance between Cost and Risk, in my opinion the current Regs are an improvement in terms of safety. Take a socket outlet which is used for outdoor equipment, before the requirement of RCD's if a fault occurred it may of been "Potentially Dangerous", unfortunately there is always some risk. The new Regs reduce that risk by the requirement of a RCD, providing the RCD is correctly maintained the "potentially Dangerous" is now negated.Well I think the general concern is that if say an installation was installed to the 15th/16th and was deemed 100% safe at that time, then along comes the 17th, how can we suddenly say to a client its dangerous, it makes a mockery of the regulations.So they like the term "not fully compliant" because a new regulation does not mean the old was dangerous.
I totally agree, and you do need to assess each case, if sockets are likely to be used for outdoor use then C2 is the way to go, however if a socket has a RCD and labelled for outdoor use, would you code the rest C3, with cables flushed in walls less than 50mm then I would say C3, which is also documented under ESC recommendations,C3 = Improvement Recommended, this could cover a wide range so I think each individual inspection will have a different scenario.There is always a balance between Cost and Risk, in my opinion the current Regs are an improvement in terms of safety. Take a socket outlet which is used for outdoor equipment, before the requirement of RCD's if a fault occurred it may of been "Potentially Dangerous", unfortunately there is always some risk. The new Regs reduce that risk by the requirement of a RCD, providing the RCD is correctly maintained the "potentially Dangerous" is now negated.I think we need to be careful with the word "Retrospective", if a "potentially Dangerous" situation may of existed in a previous edition, and the new Regs negate that risk, then an improvement can be made to remove that risk, so a code 2 in my opinion.
In the OP's instance there are a lot of issues's. Code 2 "Potentially Dangerous", well most of the OP's findings are "Potentially Dangerous"
