baxi solo boiler
youngy_560
Dec 3, 2011
2
Hi my baxi solo pcb board recently decided to give up...i knew this because the boiler wouldnt always fire up unless i wobbled the pcb board around untill it ignited....soo i changed the pcb board tonight with what was an 'exact' replacement (all the terminals matched each other) but now my pump in the airing cupboard wont switch off? I know there meant to 'overun' but after 6 hours i realised it was never going to cut out . Any ideas? If i switch the boilers fused spur off and then back on again the pump stays off...soon as the boiler fires up pump comes in , soon as boiler switches off pump stays on ! Any ideas? Thanks
Yes it turned out to be a relay ? Unfortunatly the pcb board was in bad condition anyway so a replacement had to be done...will check for links tomorow... If not could a live and sw live be the wrong way round?
