The pins on these are 11mm diameter each so with a bit of drilling out of the GU10 holder :innocentThat won't fit a GU10 base.
The below (not my picture) is different to the one that would take the above 20kw lamp but gives you an idea of the kind of size.Working on lighthouses in your spare time now
I paid a visit to the Southstack lighthouse in Wales some years ago, interesting to learn they use a 150w bulb and the lens allows it to be visible some 24 miles out to sea.
Every day is a school day!The high magnification of the Lighthouse lens is one reason why they rotate...
(and keep rotating in daylight even when the light is off)..
As if direct sunlight hit the lens at a specific angle you have a very high intensity magnifying glass in reverse..
So instead of burning ants, like you did as kid in the garden..
you would overheating and damage the light source.
With a mercury filtery thing!I've been wondering since just how you filter mercury.
I'm usually quick to google, but I thought cleaning mercury too far out to bother. Perhaps nothing is beyond google!Just googled it filter paper with a couple of pinholes at the apex squeeze through a chamois leather
seriously!
They're incredible buildings. Some pictures below of the one we visited. I too was surprised about the size of the lens structure, huge, a lot of chunky glass. There's a huge amount of kit in the building below it to power and run the thing too.Lighthouses are fascinating. I visited one on the north east coast a couple of years ago and learned that the lens structure is floating on mercury as a bearing. It was massive , seen close up, and you could move it with one finger. They also said that the mercury has to be drained and filtered occasionally to remove any dust etc. I've been wondering since just how you filter mercury.
