I agree Apache and have moved it. That does look nasty Tom1, could have been quite serious consequences if it had not been identified in time.Gosh.Should be in black museum!
Thanks DocI agree Apache and have moved it. That does look nasty Tom1, could have been quite serious consequences if it had not been identified in time.Doc H.
thats what i thought, fuse wire still in tack, do you think it has been replaced with some other cable?8.5 kw shower is at lest 35 amps its just been overloaded.
i find a nail is much betterthats what i thought, fuse wire still in tack, do you think it has been replaced with some other cable?
possibly, but even if it hasnt been changed for a nail etc, it would never blow with 35Athats what i thought, fuse wire still in tack, do you think it has been replaced with some other cable?
6mm bonding will need changing to 10mm 1mm cpc akthough not ideal would mean complete circuit rewirechanged the cu now, put it on a 40Acouple of things flagged up, 0.69 M ohm on 1 of the light circuits,
and what looks to be 1mm cpc on the ring.
6mm bonding would be a ball ache to change,
am i right in thinking i dont have to fix/ upgrade all these?
Can I ask how or where you know that from Badger? In the past I've been led to believe by a very experienced periodic specialist old spark that as long as the 6mm is yellow and green (as opposed to just green) you don't have to upgrade the main bonding and this was what we always used to work to. I'd love to prove him wrong on something!6mm bonding will need changing to 10mm
Agreed..Possibly loose connection onto fuse way caused the burn out, have found several of these over the years.
I'm sure there was a post on here regarding bonding just the other day . I'm sure that someone will confirm it but It could depend on the earthing arrangement itself . I would change the bonding myself as the board has been changed , as for the I R on the lighting circuit it is a fail under the current regs and needs investigating . How old does the cable look on the ring ? :|changed the cu now, put it on a 40Acouple of things flagged up, 0.69 M ohm on 1 of the light circuits,
