install it your way. its your name on the cert, not his.What should i say to him or how should i install it?
Yeah just a rough gestimate its no more than 12".If it was 12'' from window frame I would not think their is much chance of a curtain rail fixing hitting a cable at that distance.Batty
I would not put cable down cavity on new build. If it is likely to get drilled into I would chop cable into wall at least 50mm where fixing is likely to be.Yeah just a rough gestimate its no more than 12".
Yeah good point batty might do that one.I would chop cable into wall at least 50mm where fixing is likely to be.Batty
Ask him to confirm:-Started a job on friday, started wiring a new build and this question was put to me about putting a shaver socket into a wet room it will positioned roughly 12 inchs from the window frame.Builder says can we put the cable into the cavity just incase they put a curtain rail up it avoids drilling the cable.
My reply was it will be in the prescribed zone with it being a straight vertical drop inline with the shaver socket.
He said well they dont know that do they.
erm???? THEY DO if you tell them!!
Or 2 hours special, have a brew then it might be time for a break afterwards.you are more than happy to go back for 1 hours payment to mark a suitable drill hole position for them!!
Applaud SmileyB-) :^O :^O:^OOr 2 hours special, have a brew AND a biscuit or cake!!! then it might be time for a break afterwards.
