I thought the smallest crimp dye that comes with that crimper was 4mm!I have used it inside a duel patress box, so should not be a problem in a consumer unit.
Really? Used them on solid dozens of times, never had a problem.standard crimps are for stranded conductors
I've just had a Google and cant find the technical info for that, got any links? I'm quite interested in this now tbh
I did find this silly little vid though - 80kgs + on 2.5mm solid -
If the cables are pulled tight then they are almost certainly being stressed to some degree , ergo may suffer premature failure at some point.I don't understand why you consider 'tight' or taught wires are a problem. Whether they are tight in the terminals is what you should be concerned about. Presumeably they weren't piano wire tight (?) so are you just being over cautious and inventing problems that aren't really there. It is certainly not worth a code, just make an observation in the comments. Surely?
