Car Battery Prices....... Gawd I nearly wet myself!!!!!
SPECIAL LOCATION
Trailer Boy - Electrician.
Mar 28, 2008
14,520
1,198
I decided today to replace the Car battery....
(last on was approx 4 1/2 years ago while on holiday... got RAC to come and fix it on the beach car park
I'd have spent the money on the Bosch! Their windscreen wipers outlast and outperform the others. :D
Manufactures original parts lasted 4 years 2 months
RAC 'non-brand' just under 4 1/2 years
Manufactures warranty on this new one is 3 years....
If it fails in 3 years free replacement...
even if it don't I can Buy 2 for the price of the Bosch which would give longer lifespan @ 3 years warranty each!
---------- Post Auto-Merged at 01:47 ---------- Previous post was made at 01:46 ----------
P.S.
My windscreen wipers are Bosch
Get the old battery down to your local scrapyard ... The last time I was there they where giving a minimum of
Batts are expensive these days , during the "Great Thunderbird non Starting Debacle " of 2011 , all that useless cranking of the engine soon showed up a tired battery ,so
anyone ever used one of these on a car battery?
we use a '3' (the older model) on the race bikes, they run total loss so are virtually completely drained before charging, and the batteries do a couple of years racing usually.
You could also keep your old battery in case you get a cracked radiator How to fix your radiator on the road - YouTube
Brilliant!
I remember watching Steed in The Avengers put an egg into the Rad. The heat poached the egg and blocked the leak.
I tried it...must have used wrong sort of egg! Whoops.....not what I eggspected................... :coat
After 24 years in automotive R&D, I can vouch for the quality of Bosch batteries. They are pretty much the best.
You're quite right Rev, you should use a good quality automatic charger especially for sealed batteries. If you overcharge then the electrolyte boils off and seriously damages the battery (by warping the internal plates which can touch and cause internal shorts).
BTW folks: make sure you charge your batteries whilst ambient temperatures are around 5 to 7 degrees C. Below 5C the battery becomes progressively less able to accept charge and won't accept charge at all below 0C.
