Changing polarity question
Jindivik
Jun 5, 2021
2
Hello from Australia,
I am assisting with a project car it’s a 59 Morris 1000 that is having a Datsun engine installed in the process the car is being converted to Neg earth. Everything is working fine except the fuel gauge. The gauge has two wires battery pos and sender. Should it still work with the change of polarity? What it is doing is that with the sender wire earthed it energised but does not deflect. The odd thing is if you turn the gauge up side down and the needle goes to full and you power it up it then deflects. What’s going on here, any help would be great.
Yes I have, you get the same result, the the gauge energise you see a very small deflection, this is the same swapping wires across, but if you invert the gauge and the needle swings across, when you power it up it goes full deflection also does this if you swap the wires across. I’m really at a loss to what is going on here……
Morris wiring was never brilliant, Joseph Lucas is often referred to as the Lord of Darkness...
On a serious note it may need stripping down and the coils looking at.
Joseph Lucas was well known for putting a little bit of smoke inside all his electrical components. The trick is in keeping the smoke INSIDE, once it comes out you are Starmered
interesting choice of words as usual Kerching
starmered - don’t think I’ve come across this one before???
Starmered v.  Past  tense of the verb, to Starmer ....to render useless, to ruin, to knacker, to courgette
derived from the foppish haired , band wagon jumper, "it would have been better if I had done it! Well except local elections obviously, " ponce leading the Labour Party. Face like a slapped arse
quote..."well M'lady, if we do not call the local fire brigade soon the entire thatched roof will be well and truly Starmered. I fear that your spitting on the flames will have little or no effect!...may I proceed?"
from 'Lady Cynthia and the missing members of Trumpton' by Barbara Carthorse
To come back to the original query, it does appear to me likely that the indicator itself is probably at fault.
From my recollection of my bangers, sorry classic cars, these fuel gauges were very "low tech."
The tank sender is a potentiometer moved by a cork on an arm a bit like a ball valve.
The indicator was either thermal or moving iron meter style. The more sophisticated ones used a voltage regulator, but I think that was thermal/mechanical.
Nothing I can recall that was polarity sensitive.
Hence I suspect it's demise during you present work is down to co-incidence, or sods law if you like.
