No, if you test Ir and ring continuity that would be testing stuff outside of the CU.so i can give a EIC with limited test results?i.e from the CU i can check IR,ring continuity
note on the EIC restricted access jobs a good un?
Test the CU, you could fill at least 2 or 3 pages of a PIR without even having a circuit connected to it.
