cheap CU wasn't too bad
constructive comments welcomed
Nice job lostit, but you did ask......
no circuit schedule:x
no periodic inspection label:|
wallpapering not made good:coat
best wishes
Alan
Also, the listing that you linked to on FleaBay, looks like the "Ching" brand.
The chinese ones. I think that is the correct name?!
Brother bought one a couple of years ago, from TS.
best wishes
Alan
the circuit schedule is there its below the mcb's
the rest hands up :x
no testing in that list lurch:x
I knew someone was going to pick that up at some point, surprised it took this long!
You only need to test if the lights don;t come back on anyway. ;)
I'm with KME, every circuit gets tested post cu swap out & full EIC is issued & a pir sticker is placed on the cu along with the rest.
I don
I don
Is that right a full eic should be issued personally I issue limited eic with loop readings on it as you have only changed protective device. I would be careful issueing a full eic as you did not install wiring and if something goes wrong it could open a can of worms for you.
An EIC is an EIC. same cert whether its a full EIC or not.
just make sure your description clearly states CU change only
