Hi All,
When changing a CU and the meter tails .Am i allowed to also change the meter tails from the cut out to the meter as these are also the incorrect size for current regs.
Also does anyone know of an easy way to identify cross sectional area on larger singles cables from 6mm upwards. As i am new to this it is causing me some probs having to carry samples to compare against.Is thier any rule of thumb so to speak or is it just recognitian with experience????
Cheers Rob
Cheers Rob
