maybe get Admin2 to ban you from the forum so there are no distractions until its doneSo Much to do and so little time to do it in - I am Nervous. :_| The college are changing the 2330 from a two year course to a three year course form September.
it will all be worth it once you finish though. sometimes gotta make sacrifices to get it doneI have hardly been on here Andy Mate. :_|
well, thats bit of an easier way than my method!Good luck with the exam Admin/WW. I'm sure you'ld do wellStarted the assignment write up last week, but exams arent til june.
As for the questions, isnt it I = P / (V x pf) so 11.4A
There is no need to work out the current... ?:|Q2 Need to work out the current firstAMPERES = POWER / VOLTS
3KW(3000) / 230V = 13A
Then for the resistance
RES = VOLTS / AMPERES
230V / 13A = 17.6ohm
or evenThere is no need to work out the current... ?:| why not just go straight to resistance? :|
230v X 230v/3000w = Resistance.
52900/3000 = 17.6ohm
If you can remember how to transpose the main formula it can save time in exams.
i.e. because we know
P=VxI
and I=V/R
therefore P=(VxV)/R
so R=(VxV)/P
HTHGuiness Drink
Concur with point 1.Sorry folks but this is defiantly level 2 stuff, some elements will transfer to level 3 but these are level 2 questions all the same.As for exams i have...
ECS Health & Safety This Wednesday
203 the following Wednesday
206 on Saturday 23rd
205 on June 17th
Gonna be a hectic few months i think.
:^Oso much easier once your qualified....then you just have to go through yearly assessments if you want to be part of a scam
or evenR = V
my calc gave me this:Hi folks please correct me if this is wrong but could the formula for question 1 be
I = P/V x PF
I = 2500/230 x .95
I = 10.32 Amps
is there a difference in formulas when we have "the power dissapated" or when "power is consumed"
Pat
you are using the brackets wrong. The calculator gives priority to the brackets.my calc gave me this:2500/(230 x 0.95)=11.44a
Just think slowly thorough what we are trying to achivewhen i do it this way 2500/230=10.86 then 10.86 x 0.95 = 10.32awhen i do it the way we have been taught in college using fraction button (casio fx-83es) it comes out:
230x0.95-218.5 then 2500/218.5=11.44a
Also same question is q.14 on paper 2 on admins 301 questions and the answer sheet says it is 11.44a
Confused now as to what is correct! ?:|
No!Apache I am in no way doubting your god given talents and your method does seem to make sense to me as well but are you 100% sure your way is correct?
