- Joined
- Oct 22, 2010
- Messages
- 14,621
- Reaction score
- 1,171
So may as well bite the bullet
unswitched sockets C2
not enough sockets C2
no smoke detection C1
The one I was asked to look at was noted as PVC!plastic fuseboard - C2 ( just nonsense)
I've always been baffled by some Spark,s penchant for becoming a policeman , Clerk of Works or architects .not enough sockets C2
Whether there are smoke detectors fitted or not is not within the remit of an electrician . In my opinion . I'd say the householder or landlord should be taking on that responsibility .
gob smackedNo harmonisation label - C1
"Be careful when fiddling about in here as there may be stuff you don't understand or know what to do with"...well you shouldn't be pratting about in there anyway!gob smacked
these labels aren’t even necessary imho
I forgot to add, it didn't need one, was in all new colours.gob smacked
I can see the need in a domestic situation where the homeowner may not be aware
Ex courgetting actly!then they shouldn’t be taking the cover off the CU
But they could come across mixed wiring when swapping socket fronts etc that have had spurs added...then they shouldn’t be taking the cover off the CU
So....2 reds and a brown in one terminal with a L on itBut they could come across mixed wiring when swapping socket fronts etc that have had spurs added...
And how many posts on another forum such as I've changed my light and now it doesn't work/stays on/goes bang...if they cant remeber this connection between taking the old one off and fitting the new one then Mr Darwin needs to call
You have a bit of a simplistic approach to the function and construction of a heat detectorI don't have a problem with a SMOKE detector having a "replace by" date, as the sensor has a finite life.
But heat detectors also having a replace by date is the manufacturers taking the P / cashing in. the sensor is a thermistor and no reason why that should wear out and need replacing. So i ignore the replace by date on a heat detector.
