Di-LOG DL6790
steptoe
Feb 13, 2008
24,404
168
Gtr Manchester
OK, so Ive now had the Di-LOG DL6790 CombiVolt 2 from our forum sponsor isswww for a while now so I thought it time to give it a review.
first impressions, doesnt feel like cheap chinese tat,(although on investigation the label says 'made in china' ! )
actually feels quite rugged, with that nice soft rubber grip feel to it, rather than just hard shiny plastic.
first things first, pull out the little tab isolating the batteries in transit, remove the protective cap(that is attached to the lead for safe keeping), that covers the GS38 compliant probes, and stick it into the nearest socket in the house,(by the way, the 2nd probe neatly slots into the main body of the tester),
instruction manual carefully strewn on the floor somewhere, Im a bloke, I dont need destruction manuals.!
anyway, it lights up and works, so have a rummage for instructions and lets see what it actually does, apart from light up and beep/buzz.
test range, 12-690v AC + DC , not that I'll be needing much of the 690v DC !
an ascending row of red LEDs on the left give a quick visual indication of a voltage present, with a pair at the bottom indicating either AC or DC flowing, underneath is a large LCD display giving out the actual voltage,
fairly posh for something in this price range.
above the LCD on the right is a yellow LED for continuity, which glows and buzzes for doing quick bell tests on unknown wires,
handy to use rather than your multimeter set to the wrong scale/range,
this is a really good function, as this little tester is auto-functioning it will automatically select voltage in the first instance every time, so if you go to do a continuity test and there is voltage present it will simply buzz up a warning, the red LEDs will light and the voltage will be shown on the LCD display,
rather than blow up your costly DMM cos you had it on ohms and put 230v across it, :(
the next BIG thing about this little wizard is one of the things Im quite taken by,
Phase rotation, now if you do not work on 3 phase this is a redundant feature, but who knows, some day you may just require it, and it is now a requirement of the test procedure in BS7671/2008 to be able to verify this.
simply place the two probes on neighbouring phases and one of the two green LEDs will light up to indicate in which direction the phases are running,
repeat again for the next pair, and finally the 3rd pair, really very simple, and without the need to go out and buy either a dedicated phase rotation meter or upgrade your existing MFT.
and now for the BIGGIE, those of you that know me may well be surprised by this, I have not used a neon since the 2nd day I got this,
this little guy does single touch testing,
simple touch the main probe unto a live conductor and if there is a voltage present then it lights up and buzzes, OK, so it doesnt show the voltage, but neither does a neon, and this one doesnt expose you to the possibility of becoming part of the potentially lethal circuit. now of course you know the wire is at a voltage potential you can find yourself a suitable earth reference for the other probe and take an accurate voltage reading of how many volts are actually on the cable, I have found this feature invaluable for the same reason I previously found the (now defunct) neon indispensable, fault finding, especially on borrowed or broken neutrals.
this little guy has been by my side since I got it,
pretty much invaluable, wish I had actually bought one ages ago,
all in all, I could definitely recommend this to anyone that is needing a cheap and cheerful basic tester, although its not really that basic TBH, it does quite a bit more than I would expect for the price range.
for me, the last two items I mentioned would probably justify the price alone.
stars out of 5
clicky
Great review,
Comprehensive, concise and complete.
Nice one :Salute
you forgot to mention the torch ;)
I have the fluke t100 and didn't find the torch for a couple of weeks.
Just had a look on ISS, it says will never trip RCD's when testing live to earth. Steps, can you tell me if you have to put the probes on L&N first before L&E to stop the RCD tripping?
This is what I need to do on my Fluke voltage tester, however sometimes I forgot, like the other week when checking a JB in a loft and I tripped the RCD because I did L-E first!
So........as I am looking at a new voltage tester (present one casing and probes cracked) then I might choose Dilog over the Fluke.
Just had a look on ISS, it says will never trip RCD's when testing live to earth. Steps, can you tell me if you have to put the probes on L&N first before L&E to stop the RCD tripping?This is what I need to do on my Fluke voltage tester, however sometimes I forgot, like the other week when checking a JB in a loft and I tripped the RCD because I did L-E first!
I will check for you tomorrow Robin,
but so far Ive not tripped any RCDs and I usually always do LE as I dont know if N is actually there, sometimes I just do L to an earth reference, but I dont think it will as it does a single probe buzzer, like a neon only safer.
will deffo get back to you on that though.
Took this directly from the Dilog web site, they have always told us they do not trip RCD,
Features;
it doesnt trip RCDs,(well not 30mA,100mA or 500mA, havent had a chance to test any other sizes), not any that I have tested anyway, whatever way you put the probes on, :D
Thats great Steptoe, thanks for your help on that one.
It looks like Megger Mark will be getting some more money out of me this week then.
Well my Dilog tester has come today (ordered from Megger Mark), and yes for the money i can confirm its a good product and unlike my Fluke T100 it does not trip the RCD when testing L-E so this will be a great help. I also noticed the light has a really powerful LED and is a lot brighter than the Fluke T100.
Thanks Steptoe for your review on this it has really helped me out!
look next to the probe on the main body, theres a little LED there.
doesnt work,
unless Im not pressing the right bit, although I now see a symbol for a light,.
but, I cant really take any marks off cos I didnt even know it had one. :|
---------- Post Auto-Merged at 22:34 ---------- Previous post was made at 22:30 ----------
Well my Dilog tester has come today (ordered from Megger Mark), and yes for the money i can confirm its a good product and unlike my Fluke T100 it does not trip the RCD when testing L-E so this will be a great help. I also noticed the light has a really powerful LED and is a lot brighter than the Fluke T100.Thanks Steptoe for your review on this it has really helped me out!
you are very welcome Robin,
Megger Mark was prob a little dubious if I done one,
I dont know,
but if its good I say so,
if I dont think its good I say so,
only my opinion mind,
and as I have said, the light on mine still doesnt work, but as I have already gave it top marks would be unfair to now mark it down seeing as I didnt even know it had a light,
teach me to read the manual!
even with that sentiment, I dont see that one small issue as a reason NOT to still recommend this to anyone,
just take it as no light, and if it does have one then that is an extra.
The button to operate the light is on the reverse side to the display, and if it does not work then send it back they have a 24 month warranty!
Had a set of Di-logs (previous version) for many years until i bought a pair of Kewtechs cos they don't trip RCD. Di-logs were passed on to apprentice and are still going strong after 6 years. Kewtech has irritating battery connection - ie doesn't always make contact properly, and are only 18months old). Will be buying di-logs again in future cos there'snothing more irritating or dangerous than faulty test probes.
