Simon Ravi
- Feb 10, 2012
- 1
- 0
I recently purchased and installed (via an electrician) a DuoHeat 500n in my living room. Unfortunately, its not heating up my living room.
As you might know, the Duo has two heat supplies:
(1) BACKGROUND - via an of-peak connection and this is the stored heat
(2) COMFORT - via an On-Peak Connection and this is an electric panel on the front of the heater that is meant to provide additional heat in the evenings.
The background heat is released automatically with the help of a room temp sensor.
Each night I set the BACKGROUND HEAT TO MAX (this controls how much is stored over night) and the COMFORT heat to low (2 bars out of 10). When I wake up in the morning the storage heater is very hot to touch (both at the front and the side) but my room is not heated. The heater remains hot throughout the day but does not heat my room. So it looks as if its not efficiently releasing the stored heat.
Therefore, I was wondering if the heat coming from the front "COMFORT" heater is affecting the the temp sensor which controls how much stored heat is released, fooling it into thinking that the room is warm and so no significant heat needs to be released.
Therefore, I was thinking of switching off the ON-PEAK "COMFORT" supply overnight and just leaving on the "OF-PEAK" to see if that works. However, I read somewhere that both need to be on for the heater to work and fear I might destroy the heater.
headbang
headbang
