I think the reason why I couldn't remove the fuse holder on the existing switch is because it had progressively got warm and then eventually deformed the plastic inside. These was same discolouration inside.If there is a fault on heater it will blow the mcb. A 13 amp switch spur will probably be ok for a while but it will get hot and eventually pack in. I personally think there is a fault on heater that is why fuse has gone.Batty
Yes our's doesn't change in the summer so I have to stay up until 1am to put the dishwasher onJust popped over to check.Good news. Heater was working fine. Neon was still on as E7 was still live. (I thnk the E7 clock is out by an hour because of BST).
Mine doesn't get warm but them that know will surly chip in. There should be a thermostat so it's not drawing current ALL the time it's live. I'm sure ours use most electric when E7 kicks in and very little after they have charged for a few hours. The more I think about it the less I think I think the Sw connection plate and MCB should be warmBut I did notice that the new switch I fitted was warm to the touch. I suppose this is normal as it's got about 14amps running through it?The mcb was also slightly warmer than the other two in the board (the other two mcb's are for another storage heater and the immersion heater. Both were switched of locally so not pulling any current.)
Should I be concerned that the switch on the wall was a bit warm? It is definitely a 20A DP switch. I fitted this one.
