ianmacd
- Mar 15, 2009
- 3,877
- 0
You got a reg to confirm that2. This is the most interesting thread that's been on the forum for months in my opinion.
These are irrelevant as the cables are protected by an RCBO.ive said before, it only complies if the cable can withstand a fault current which needs confirmation with adiabatic equation. You also need to know the pfc . the Zs and Ze.Where we take the pfc i am not sure, normally you would do it at the cable end, but i dont understand that cos who knows where the fault will occur.
Eg we may find that a 2.5 radial done in singles with the same size cpc in conduit complies, but 2.5 t&e doesnot. Who knows until the equations are done. Come on lets get this done. ray
No, but no-one has quoted a reg saying it's not so I win! ROTFWLYou got a reg to confirm that
Are you a part-time politician? You swerve questions wellWell you ref appnx 15 but not a proper reg so actually you can not prove its complaint either.
What is providing 'Overload' protection for the 2.5mm cable? bad day explode
That's easy for you to saytake this onboard please.
] ROTFWLC'mon Ian.I'll give you a clue ...... It begins with BS
Do you want another?? ..... It contains 4 numbers BS 1234
Another?? ....... It's found in a plug-top. (Aw c**p, I've gone too far, you'll get it now )
C'mon Ian, I want to see you write it
well said that man!! finally some sense :Applaud :ApplaudOK, enough rubbish,now we are gonna have the LAW,
would any person complying with the LAW that is EAWR 16 design such a circuit.?
IMO if you did design such a circuit then you would be in breach of EAWR,
and therefore,
could NOT by default comply with BS7671,
as 7671 requires you to adhere to the law at all times.
And how, exactly, is it not complying with the law.OK, enough rubbish,now we are gonna have the LAW,
and therefore,
Persons to be competent to prevent danger and injury16. No person shall be engaged in any work activity where technical knowledge or experience is necessary to prevent danger or, where appropriate, injury, unless he possesses such knowledge or experience, or is under such degree of supervision as may be appropriate having regard to the nature of the work.
As we have proven that the circuit doesn't present 'danger or risk of injury' and complies with BS7671, then we have proven our competence and this doesn't really apply.
I already did and am bored with repeating myself. Nothing suitable is but that seems to be allowed under the regs.Maybe you'ld like to answer the questions posed in 'Post #342', as Ian doesn't seem to want to. ; \
