That is still a bit of a grey area as if you follow the example in the appendix with 4mm radial then, yes, it now complies, but they do not seem to back it up with a reg number that allows it. Has anyone found one? They do one for rings why not for 4mm radials?
There are 2 things to point out here too:
1) Its electrically no different but the regs (potentially) allow for this scenario, therefore it (potentially) complies when it did not run in all 2.5mm. Stupid, I know but they are the regs.
2) As pointed out by most people, the OP's example would not normally be practised.
IMHO when you install a new circuit, there should be no need to have spurs. Spurs should be left for later modifications. I look forward to a time when both Rings and Spurs are no longer part of the regs.
