A thought for the people who believe the ops scenario doesn't comply.You turn up to do a PIR on a property and come across the ops scenario with no spare ways in the CU.
What do you do?
Tell the customer that it fails as it doesn't comply with BS7671 and advise swapping the 32A RCBO for a 20A.
The customer says
That won't work, mate, I've got a fixed load on my FCU drawing 10A, and the equipment plugged into the double socket draws 10A each.
That gives a design current of total 30 amps off the RCBO, a 20A one will keep tripping:|"
What do you do now?
Tell the customer that the 2.5mm cable isn't suitable and you'll have to rip the premises apart and replace it with 4mm.
Customer says
"Each 2.5mm cable can carry up to 27A, neither cable is carrying anywhere near that, I'm not happy with your recommendation."
So what? You fail a perfectly safe and compliant installation. Get a life
