We have the draft EIC.Has an EIC been issued yet.
No such thing as a draft you either have a complete EIC or you don't.We have the draft EIC.
any intereference with the system voids paperwork and warranties. It's a common problem with gear and electrical work, if there's a problem you need to contact the installer / manufacturer to sort it out rather than open gear up and investigate problems yourself. Any mention or evidence of interferenece and everybody says warranty is void, even if the problem was clearly their work or materials.Another quick question. Does the removal of the fascias make an EIC void?
it's not unusual to have back boxes set deeper than flush, that's why you can buy longer facia screws, which every sparky has. The important part is the back box being fixed securely, and sometimes that is achieved with the plastering due to, for example, crumbling bricks.The penny finally dropped on this statement! The hole is too deep for a standard back box. A deeper back box would help to alleviate that particular problem.
^^ not sure I agree with the 21 days
With NAPIT you have 21 days to notify for Part P which is not the EIC
The EIC is normally issued with the completion certificate
So you have altered the system.The only thing I changed were three switched double sockets for three switched double USB sockets.
I can only repeat what I was told.
I don't even know what that means
He still owes you an EIC, which is a legal requirement and
Think it's under building control legislation. But I do know it's not legal to withhold a cert even if the customer is a complete Richard the Third.BS7671 is not law
He still owes you an EIC, which is a legal requirement and cannot be withheld even if you haven't paid in full.
Part P compliance is a building reg and a rewire falls under it. As your spark is a Napit member, he can self certify his work.
so he owes you the part p compliance certificate as well as the EIC
