- Nov 28, 2009
- 14,762
- 951
Todays job that I had to abort and re group when i have worked out how to do it.
Mobile catering trailer, wants an extra socket. The entire worktop is stainless steel sheet on a wooden (block board?) backing.
To get the new socket where they want, I need a 20mm hole through the stainless steel worktop and through the wooden board underneath it. the hole will be very close to the wall (normal conduit standoff distance, just a few mm)
So I can drill a pilot hole with a sharp HSS drill bit, but I only had a few small drill bits with me. So how to open that up to 20mm? My cordless drill will only go up to 13mm, so even if I had a full set of drill bits, that's the largest I could go with that. I don't think my stepped cone cutter would do it, that struggles on mild steel.
All I can think is a new, non stepped cone cutter?
How would you do it?
