- Mar 28, 2008
- 14,295
- 945
The question was about regs not if they are any good
Yes we have all come across RCDs tripping and people losing half there house a pain but not rocket science to repair.
If the customer doesn’t want to pay the extra £200 for RCBOs it’s on them
I don’t use them as a rule but preference is not a regulation
Regulation 531.3.2
Repairs may not be rocket science....
But if you've been doing this job for more than a couple of years, will be aware they can be long, drawn out and expensive on labour / call-out charges... Whilst trying to establish exactly which circuit(s) is/are causing the tripping... especially if its an intermittent fault.
and can easily mount up to multiple days labour costs....
Customer soon get very irritated if they a loosing power frequently at a critical time..
And get very concerned that the power may trip off while they are away from home / on holiday..
so they come back to a freezer that has thawed out..
typically considering this a bit more than just 'a pain'.
And when you have got the power back on... and the customer asks "how can we stop this happening again?"
the answer is.... take out the cheap tat of a dual RCD CU that captain cowboy fitted..
and install a more professional solution.
The costs of fixing these problems is generally a lot more expensive when offset against a full RCBO board..
But if the customer is not being given the realistic remedial costs to compare with a dual RCD option..
then they don't stand much chance of making a sensible decision do they?
Reg's are guidance
and when there is a cost effective easy way to...
"minimise inconvenience in the event of a fault" 314.1 (i)
and
"reduce the possibility of unwanted tripping of RCDs due to excessive protective conductor currents, not due to a fault" (AKA cumulative leakage)..
314.1 (iv)
Why would any competent, experienced electrician choose to ignore guidance that provides a better design and functional solution to a prospective customer who is going to be paying their wage...?
