chrisg1979
- Oct 19, 2011
- 74
- 0
De ja vu???
Threads merged, I suspect some of our members are more shocked that anyone undertaking electrical work cannot establish if a metal item is extraneous or not. It is a fundamental design principal of BS7671 before undertaking any alterations temporary or permanent as per regulation 132. What is your measured continuity between the alleged extraneous metal part and electrical earth? At one point you are saying they are extraneous, the next point they are not.?Nobody seems to know the answer......thought as much.
I am doing a job at the mo, where gas bottles are installed outside. There three types of gas; Argon, Argon Carbon dioxide and Propane. The gas enters the building via copper piping. Do these pipes need to be bonded where they enter the building. One spark said we can cross bond off the 100mm x 100mm metal trunking. I said the gas should have its own dedicated 10mm earth from the main earth bar. Any thoughts please?
Doc H I never said I knew the answer. I'm no expert, I just saw it and thought it wasn't right that its not bonded. I havn't carried out any tests. I'm not a spark. I thought because it's gas in a copper pipe used with electrical equipment it needs bonding. Am I right or not?
I am just confused as to who is responsible for this work? On one hand it reads as though you are doing it, but then you say you are not a spark. As such it would be best to leave it to those responsible for the work to make the decisions. Hence my comments that every competent electrician should easily be able to identify if metal work is extraneous or not. Once that is established any other relevant points can be considered to make a final judgment.Sidewinder, thank you very much. Its appreciated. That's is all I asked for previously. I like this forum and it is full of some knowledgable ppl however their appears to be a very distinct attitude on here of 'I know more than you, you don't know what you are talking about, haha'. I don't testify that I'm an expert, hence why I came on here for advice, instead I got slated.
because it can only be determined on-site by testing. how exactly are we supposed to be able to do that on an internet forum, where most of us are probably hundreds of miles from you?Nobody seems to know the answer......thought as much.
