You do need to hit the Rod as well NOZ..The only things I have ever hit when whacking a rod in are my fingers or stones..
Can I just say that, if the clamp has a brass nut & bolt on it, it is a REALLY good idea to take `em off first. I do as MCBfinder says; but if you leave the nut & bolt in, the brass bolt can snap when you try & tighten it; which seems to be a direct result of the vibrations in the metal from the hammering of the rod.........hiif you have a clamp that is in one part it is always easier to put the earth rod box on the floor, put the clamp on the rod(loose), and hit it in. if you dont then the end will burr over and you will have to cut off the burr or file it.
Yep, put the clamp on first...
You can see how the newbies get confused!put the clamp on the rod(loose), and hit it in.
Put clamp on, take out nut and bolt, hit rod. Done.You can see how the newbies get confused!
I think you can go up to a mile but cable gets expensive.We put loads of these in nearly all doubled up or trebled sometimes. I've put 16 in once and still couldn't get 200ohm. Had to explain to MEA (supply authority) that everything tripped/tested OK and I had applied the 50 volt calc. (It was not far off)Just a tip if you are doubling, when you are coupling the rods damage the last few threads a bit so that you really have to double pipe grip it to tighten it. This stops it coming loose when you're bashing it in (extremely frustrating)
Does anybody know if there is a maximum distance from the house/building that your chain of rods can travel as ours do sometimes have to, to get any decent readings.
No max distance away, but there is a distance between the rods otherwise they are not as effective,We put loads of these in nearly all doubled up or trebled sometimes. I've put 16 in once and still couldn't get 200ohm. Had to explain to MEA (supply authority) that everything tripped/tested OK and I had applied the 50 volt calc. (It was not far off)Just a tip if you are doubling, when you are coupling the rods damage the last few threads a bit so that you really have to double pipe grip it to tighten it. This stops it coming loose when you're bashing it in (extremely frustrating)
legally its all you are allowed to use though.re brass bolts, they are just cheap rubbish imo
GN3 says something along the lines of electrodes should be tested (or installed??) when ground is driest.the 200 is a recommended reading not the max, this is suggested that it is a satble reading. however if you are getting 300-400 when the ground is dry then its not likly to get any worse. the max for 30ma is 1666 ohms and for 100ma 500 ohms.my nic guy has said you can go back to a job a few months later and retest if you realy want to make a point of it, just to show it hasnt changed much.
Bu..er if you want to do a job in the summer though.GN3 says something along the lines of electrodes should be tested (or installed??) when ground is driest.
Sorry Batty, I didn't know you've moved to Spain.............Bu..er if you want to do a job in the summer though.
GN3 is only guidance of course ; \Bu..er if you want to do a job in the summer though.
