- Jun 21, 2008
- 17,024
- 51
C'mon, let us in on the use of the building!
you have obviously not seen the DNO at work. seen many cases where they have done a repair or extra joint to TNS cable, bonded neutral & earth together at the join, and taken a new feed as TNCS.The 'Earthing Conductor' is either connected to the 'Neutral' conductor at the cutout or it isn't - so it's either TN-C-S or it isn't.....there's no humming and hahhing about this, regardless of whether the supply is PME or not.If it's earthed via the sheath of the incommer, it's TN-S, and there isn't a problem with the 'portacabin' being earthed and bonded via this.
Very good advise, assumptions have no place in the safe working methods of todays H&S driven work places.But I don`t think you can "second-guess" the DNO on this - irrespective of what you KNOW to be the case; you have to work on the presentation provided; NOT on your assumption of the network configuration behind it..........Or am I wrong??
thats the problem, isnt it.But I don`t think you can "second-guess" the DNO on this - irrespective of what you KNOW to be the case; you have to work on the presentation provided; NOT on your assumption of the network configuration behind it..........Or am I wrong??
