ROTFWLROTFWLROTFWLROTFWLROTFWLROTFWL
does not automatically mean PMEI wasn't going to reply to this drivel - but you gave me a 'no thanks for a useless post' :yellow card So you are telling us that the DNO would connect the outer sheath of their supply cable to the neutral conductor at some random point on their network, and not tell anyone that the supply they thought was TN-S was now running part of the way on a PEN conductor!!
For one thing, they wouldn't do it without the neutral being a PME supply (regardless of what Steptoe tells you) - and if it was a PME supply, how could they make such an alteration without informing people that PME conditions now applied to their TNS installations.
I don't think so.
TNS, by it's very definition, is a seperate earth throughout the supply and installation.
TNC-S, by it's definition, is combined PEN on the supply side and seperated at the consumer installation.
What are you calling your description....TNC-S-S??![]()
I don't think so.
Hi Sidewinder,ADS,In my area the DNO have not installed any TN-S cabling for over 20 years, any renewals to TN-S supplies are via PME.
This is I am lead to believe common practice as it is cheap.
I realise what you are saying about the definitions in 7671 but this does not apply in DNO land, check ESQCR.
Sorry bud, that's the way it is thees days, PME is CHEAP!
why have you put TNCS and the PME in brackets.?Hi Sidewinder,I'm not saying they won't convert existing TNS to TNC-S (PME) at the origin of the installation.
I'm saying they won't convert it half way down the supply line without telling anyone - letting you think you still have TNS, when in effect you have a CNE.
They may convert the supply to PME, but that won't affect the TNS installations until such time as it becomes necessary to convert them.......at the origin(cutout)
No, it means it is a TNCS earthing system off a PME supply - why do I have to explain this to you again??why have you put TNCS and the PME in brackets.?is it the same thing? or have you reason to assume so.?
please do not assume,No, it means it is a TNCS earthing system off a PME supply - why do I have to explain this to you again??The only other supply for TNCS is PNB - which I would have written as TNC-S (PNB)
Please stop the attempts at putting people down, Steptoe - give a reasonable argument, or say nothing.![]()
Sidewinder, I agree with you - it's Andy I was disagreeing with.ADS,You have now confused me!
Not difficult at this time!
I'm saying the DNO's change the local area cabling from TN-S to PME without telling anyone and have been doing for 20+ years.
It is only the last link to the premises they don't change.
Perhaps you'd better have another go, or I'd better come back later on after some sleep!!!
