freedomrun
- Feb 3, 2010
- 65
- 0
TN-C-S Domestic, CU change required. Luminaire in a Metal housing used in the Kitchen and owner wants it to stay, seems that some work has been done in the past and i cannot find any Earth continuity on this lighting circuit back to the present CU, although a cpc is connected to each light on the cct. The property has another lighting circuit that is all OK, is it permissible to use the cpc from this circuit to supply the other lighting cct with the broken cpc. If not, what if i supply both lighting circuits from the same MCB? Customer does not want to pay for me to fault find the problem or replace the Kitchen light with a double insulated type. Cheers.
