Adrian Sadler
Hiya
Just started using Easycert and wondered how to do the following scererio......
Henley block to kmf then that feeds armoured to a 6 way board in outhouse
The way I just did it was 2 seperate certs - one for the kmf install as a board - and another as the armoured and CU
Would one cert with 2 db sheets be ok? Im new to this software so be gentle.....
Another way could be to use a non domestic cert where on the db test page you can show its not connected to the origin.
Is is possable to make a mish mash cert template using different pages of different certs?
