Hi there any advice greatly appreciated,
I recently purchased my first house. A 1928 built end terrace. I am a complete novice regarding home improvements is the first thing to say, so sorry if I don't know all the correct names of things!
I selected an electrician through a "trusted trader" website affiliated with a government website. I wished for 6 sockets to have their positions moved.
When the sockets were fitted the metal box part of the sockets were very deep in the wall and not in any way level. The metal box part of the sockets were anything from 4mm to 20mm deep in the wall. They were not level in the vertical or horizontal plane or flush with the existing plaster.
The electrician also attempted to place a flush socket in a lathe and plaster wall and left me with a massive hole between two rooms which he crudely filled with concrete and bricks.
The electrician has assured me that there will not be a problem with plastering around these sunken metal boxes or fixing the front plates to the wall, as he can use long screws to attach the frontplates to the deep metal boxes.
Is this common practice, is this even safe to have a large gap 2cm or more between the metal boxes and the front plates? I have had 3 plasterers out and they all say that the metal boxes should be level and flush with the existing plaster and that he should not have attempted to put a flush socket in a lathe and plaster wall!
Thanks, any advice greatly appreciated,
Jimmy
Jimmy
