Hi, hope you guys can help with a few basic questions about EV charger installations.
I'm assuming they have to have a dedicated feed to the CU with a 32A breaker - this is for a 7Kw charger - and I think that means a 6mm cable.
If I run that under the floorboards does it need to be in SWA?
Once through the house wall what are the regs about how the cable is run? Are there height requirements etc.
My CU is under the stairs in the middle of a semi-detached and we've solid wood flooring so access will be an issue.
Needless to say I won't be doing this work but want to understand options rather than have to accept the quickest, easiest option for the installer. Don't want it looking like a dogs dinner if I can help it.
Paul
Paul
