Nice point but how can this practically be achieved when you have no access to neighbours ?:| ? :| ?:|
part 16, I wopuld think, whereby you MAY be allowed some leeway in the assumption that their installation was also installed by a competent person, although may not be to the current edition of the regs.
as I also said before,
cost cannot and must not be used as a reason not to ensure total safety, this is where you rely on the section 16 argument in court.
Im sure someone will be able to point the relevant section out to you if you havent already read it, IT is there somewhere.
worded along the lines of,
where the danger is that of potentially fatal injury (ie, electrocution) cost will not have any relevance.
thats probably totally wrong, but it is there, BS7671 is only a guide for people to follow to keep reasonably safe in most circumstances, if you really have to follow it every time you do something then I think you would fail to meet the requirements of section 16, thereby you would be in the deep stuff in court.
sorry if you think Im banging on a bit,
but this is whe you can get yourself in a lot of trouble by thinking just because you have done it to BS7671 it will be ok,
many many times I have come across plainly dangerous installations even tho they complied fully to the relevant(current) edition of the regs.
have a look in the regs and see what it says about exporting various earthing systems and what precautions are required for them, it dont really say much at all.
complying with the regs can usually be used to aid your compliance with section 16, but it can NEVER be used as a subsitute.
