- Feb 27, 2008
- 11,015
- 0
Getting 25mm swa through ceiling joists will be a nightmare. Does it need to be 25mm for a 60 amp supply? Use 16mm and keep insulation off.
Saves all the messing about and chased into a wall keeps it out of sight and gives the desired end result, but for an insulated DB I've always glanced it into an end box to get a fly lead for the armour and then taken that and the 3 cores into the DB then stripped the inner insulation offThats how I saw it Northern , forget the conduit , use 3 core SWA , even just gland it at the mains end , don't make it off at the board.
WIRELESS,,,,,,,,,Im still wanting to know how OP is going to extend all the existing cables to the new CU without anything showing.......
Twist & tape in the cavity????Im still wanting to know how OP is going to extend all the existing cables to the new CU without anything showing.......
