It is the same as the old AM2 as the new AM2 requires wiring of data cable as far as i know. I emaild regarding the changes to the AM2 and this did not affect the scottish equivilant "FICA".
Now to answer your question,,,,, i done mine in the last year but its a little hazey now.... but as far as i can remember,
On the pices of paper it asks you to carry out a test (for the life of me i cant remember what it is) but it says something allong the lines of testing the motor circuit but not including the actual motor.... this means you have to take the cables out of the connector blocks and put the crock clip on the cable...... i remember disconecting the motor quite clearly as you have to put the connections back in again as your booth gets inspected after inspection and testing and if its unconnected....... well thats not good.
